E-brake light comes on with brake pedal is pushed...
Old Oct 7, 2010 | 02:08 PM
shocker911's Avatar
Default E-brake light comes on with brake pedal is pushed...
I first off have NO IDEA how this is happening but it happend in the drive thru line today. I was pulling up to get my Mcdonalds and put my foot on my brake and teh E-brake light came on. I was like ummm ok took my foot off light goes out foot on brake light comes on.
my e-brake was DOWN so dont tell me it was up lol. Nothing seems to be wrong i pulled my wheel looked at the cable to see if it was stuck (it wasnt) put it all back together and then i went for a ride it did it again so i pulled the brake and dropped it and then it stoped.
Anyone got a idea lol. it seems fine E-brake still engages when i pull the handle and isnt engaged when the handle is dropped
Old Oct 7, 2010 | 02:18 PM
Drive 4 fun's Avatar
Default Re: E-brake light comes on with brake pedal is pushed...
In my 95 Integra, the "brake light" will activate for brake problems, at least ebrake on or low fluid. It is not an e-brake light.
Old Oct 7, 2010 | 02:19 PM
DB8 RHD's Avatar
Generally considered a sign that your low on brake fluid, and or your e brake signal switch is broken / wiring is messed up.
Old Oct 7, 2010 | 04:12 PM
shocker911's Avatar
its full on fluid i checked that after my E-brake cables....its weird it dosent do it now....
Old Oct 7, 2010 | 04:24 PM
fcm's Avatar
fcm
Old Fart
Remove the brake fluid reservoir cap and test the low brake fluid "switch", move the float up and down on it's shaft, making sure hand brake light only comes on when float is at bottom of shaft.
Pull the console and check the hand brake switch, make sure it will not "turn on" unless hand brake is at least at first ratchet. 94
BukThout
Apr 10, 2007 07:44 PM
Slow
Oct 29, 2002 03:38 PM
SlowazzGSR
Jun 7, 2002 10:30 PM
hybridbmw
Feb 19, 2002 10:38 AM
Andrea_Aunie
Oct 20, 2001 11:46 AM
