noob trying to fix my car
Old Oct 7, 2010 | 01:36 PM
TXEDTN's Avatar
Icon2 noob trying to fix my car
I have a 96 teg with a B18C6 motor gsr tranny and a stage 3 clutch. I was driving home when my oil light on the dash starts flashing..(not sure what that means)..i get the car to my house and pop the hood and there is what seems to be somewhat clear fluid around the top of the tranny where it was collected and where the block meets the head. can anyone help in telling me what is going on with the car and where to start fixing and if its something serious thanks
Old Oct 7, 2010 | 01:50 PM
Drive 4 fun's Avatar
Default Re: noob trying to fix my car
A title of something to do with oil light or oil problem might help others find you. I am assuming that it is your oil pressure light and will come on with low pressure, bad for your motor. Did you check the oil level? It is probably low, though oil pump and other things affect pressure.
Old Oct 7, 2010 | 02:00 PM
TXEDTN's Avatar
i checked the oil level and it seems to be where its supposed to be. i have no way of knowing when the oil was changed cause i just got the car but it looks to be really fresh oil not black at all
Old Oct 7, 2010 | 02:09 PM
Assuming it is the oil pressure light and not the need service light, then you need to find the cause before continuing to run it. Low pressure will ruin the motor. A bad sending unit will give you a false low pressure reading. Search oil light and oil pressure threads and start eliminating some of the variables. Start here, searched "oil light" in thread titles only. Also, since "b18c6" is not common is that real, european motor, or typeO?
here is the first search
https://honda-tech.com/search.php?searchid=1616855
Old Oct 7, 2010 | 09:07 PM
red96turbols's Avatar
Sorry - no matches. Please try some different terms...
Change your filter, check the sending unit. You may have a bad oil pump?
Old Oct 7, 2010 | 09:23 PM
I will try again, I thought I pasted it.
Search keywords, oil light, and seaarched titles only.
https://honda-tech.com/search.php?searchid=1621805
Old Oct 7, 2010 | 09:30 PM
I don't think you can paste searches? Same thing happened on that one. No link for lazy today!
we can google it though!
http://www.google.com/search?sourcei...tech+oil+light
Old Oct 7, 2010 | 09:59 PM
sayanything's Avatar
are you sure you have a b18c6?
hbyrd8701
Apr 6, 2010 12:52 PM
lonewsome
Jan 1, 2009 01:42 PM
m3dia_lab
Feb 5, 2007 01:20 PM
toyH22
May 31, 2006 02:05 PM
Supahr_Ed
May 27, 2006 11:51 AM
