my 96 lude idles up and down wen cold and makes funny noise????
If it does it when cold then its the fast idle valve, IACV will make it do it all the time.
Fast Idle Thermo Valve. You probably got radiator gunk and need to remove it and clean it. Had that same issue 4 months ago.
common honda problem,i believe you can just haul it apart and clean it all.
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
its a b series i believe but you get the idea
