stupid question..but...
Old Oct 7, 2010 | 09:29 AM
joeskyline06's Avatar
Default stupid question..but...
besides all this stuff, what else will i need to swap a sir into my 89 ef? it has a A6 in it right now, also can i buy the shift linkage from a junk yard from another car and make it work or do i need to buy a new one? what motor mounts will i need?
- Motor
- Cable Tranny (Y1, S1, J1)
- ECU (PR3, PW0)
- Brand New Hasport Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts*
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
Old Oct 7, 2010 | 09:39 AM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: stupid question..but...
Your stock motor mounts will not work.
Old Oct 7, 2010 | 09:40 AM
mruneek's Avatar
you can get a shift lickage out of a old teg, i think 87-90, but i will still have to get like 2 inchs cut out of it and welded back togeter, out you can order hasports, inovative has some to i think, or you can go with the sir one fits perfect... as for mounts ebay carries some steel poly ones for like 60 bucks or you can get hasports 300 bucks. as for all the stuff you named, u could of just said complete motor and tranny, ecu, shift linkage, mounts, axles. oh and the axles u can use 92-93 gsr non abs 60 buck at autozone and lifetime warrenty ..
Old Oct 7, 2010 | 09:45 AM
mruneek's Avatar
i wouldnt suggest doing this yourself unless you know wiring, due to the fact that u must rewire the dizzy with your si one and vtec.. hasport makes plug and play harnesses... all in how much u want to spend
Old Oct 7, 2010 | 10:04 AM
well i already have a a6 swap so i found out i wont need the throttle cable, i will pobably just spend the money on a hasport plug and play because it will be easier and if i can buy that and save the time from having to wire ill be a lot happier
Old Oct 9, 2010 | 05:40 AM
if i get that hasport sub harness for the vtec and w/e else it deals with will that take wiring out of the question?
Old Oct 9, 2010 | 10:59 AM
D16SiHatch's Avatar
basically yea. the hasport ecu jumper with subharness and dizzy adapter take care of the wiring. for anything else you might need to know in regards to the swap check out the linky
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
Old Oct 9, 2010 | 11:23 AM
mruneek's Avatar
^^ there u go everything that u need to know.. D16sihatch great write up by the way
Old Oct 9, 2010 | 05:06 PM
zCivic's Avatar
You do realize this post listed shows the DX to SI swap. He already has a A6 which is SI MPFI. He only needs to add wires for VTEC spool, VTEC oil pressure and the 2nd o2 sensor (which OBD0 DOHC vtec use 2 in the upper section of manifold). You can either get a shift linkage prefabbed or use a 90-93 teg and cut and weld both bars. You will need prefabbed motor mounts or cut and reweld your stock ones in chassis. The diz will be plug and play. Already has a A6 which is the same round plug all the OBD0 MPFI Civic/Tegs used. You can use your A6 injectors if needed. You need a B series throttle cable to fit right on the manifold. Need axles from 90-93 Teg but it depends on half shaft. Most motors come with the rear mount, but in case also needs to be a 90-93 teg
Old Oct 10, 2010 | 10:43 AM
mruneek's Avatar
there are dizzy on a a6 (SI wiring harness) is diff then the sir (b16) dizzy... yes it is a round obd0 but there are 2 more wires on the sir dizzy. not teg, sir
Old Oct 12, 2010 | 10:10 AM
zCivic's Avatar
no the a6 is 7 wires just like b16 the dx is square with 5 wires. The 5 wire plug is missing the 2 blue wires for cyl pos sensor.
Old Oct 12, 2010 | 04:40 PM
sir.rexington's Avatar
What the hell do i hook this up to? it's a 93 LS tran. in a crx
Last edited by sir.rexington; Oct 12, 2010 at 04:43 PM. Reason: wont display a photo
ALLxMOTOR EG
Feb 10, 2010 02:45 PM
palisoc05
May 24, 2008 07:42 AM
maskednegator
Sep 27, 2003 12:19 AM
mugensport9
32
Sep 7, 2003 10:04 PM
JDMHONDA89
Mar 26, 2002 09:16 PM
