pros/cons of bigger wheels
Old Oct 7, 2010 | 05:29 AM
freefall365's Avatar
Default pros/cons of bigger wheels
What are some pros and cons of putting bigger wheels on a 95 accord?
Thanks
Old Oct 7, 2010 | 05:44 AM
toyomatt84's Avatar
Sanji
Default Re: pros/cons of bigger wheels
"Bigger" as in... how much "bigger"? If you're looking to do a +1 setup (1" taller wheels than factory), you'll be looking at better cornering ability thanks to smaller sidewalls. You could go +2 to increase your performance slightly more, but 16" wheels (if you're coming from a '95 DX, +2 is a 16" wheel platform) have horrible tire options and you're looking at possible weight increases then as well.
Old Oct 8, 2010 | 03:23 PM
Cooper The Tire Rack's Avatar
Most importantly, what kind of tire are you thinking about?
If you go 'bigger' but buy the wrong tire for the application, it will be for naught.
Old Oct 12, 2010 | 11:37 AM
nsxtasy's Avatar
H-T Order of Merit
Other pros and cons... The tire selection/availability may be better, or it may be worse. (Cooper is correct, performance depends primarily on the make/model of the tire, rather than the size.) If you get really really big wheels (like 18"), with very short sidewalls on the tires, they could be much more susceptible to damage from potholes.
Old Oct 17, 2010 | 05:55 PM
OrlandoS2000's Avatar
I've also found that ride quality suffers as you move up an inch or two and the sidewall size decreases (less "cushion").
Also want to second the weight increase issue as well.... heavier wheels definitely zap a Honda's performance
Old Oct 17, 2010 | 06:07 PM
nsxtasy's Avatar
H-T Order of Merit
One more con - tires can be more expensive with bigger wheels. It's not always true - sometimes 14" can cost more than 15", and 16" can cost more than 17" - but it's usually true when you get into really big wheels, especially 18" or larger.
97Sin
Honda Civic (2006 - 2015)
Mar 1, 2014 09:46 AM
Blackout313
Dec 13, 2009 05:59 AM
Krisgh15
May 18, 2007 07:19 PM
fsp31
15
Oct 3, 2003 02:39 PM
