puttin on head gasket
Old Sep 19, 2002 | 03:51 PM
baonest1's Avatar
Default puttin on head gasket
ok well i recieved my head gasket and im gonna put it on. now i sprayed the pistons and walls and the top of the block with WD-40 and also put oil around it so it doesnt rust. should i wipe it clean before i put the head on, or just put the head on cuz the WD40 and oil doesnt matter?? my main concern is the WD-40??
is there anything special involved in puttin on a head gasket, like adding gasketmaker to anyplace or anthing, or i just line it up with dowel pins and put the head on
thanx
Old Sep 19, 2002 | 05:01 PM
Mikey3000's Avatar
Default Re: puttin on head gasket (baonest)
wipe the deck of the block and the surface of the head as clean as possible. there should be no oil, wd-40 or anything else on these surfaces. if it's a stock head gasket just put it on w/o any spray or gasketmaker or whatever.
Old Sep 19, 2002 | 05:57 PM
baonest1's Avatar
Default Re: puttin on head gasket (Salvatore Leone)
its an aftermarket "cosmetic headgasket".. ok so i clean the surface, but oil and wd-40 being in the cylinders doesnt relal matter does it.
thanx fer the help
mijos
Sep 5, 2020 05:56 PM
civicvtec16
Oct 29, 2006 10:45 AM
rathead
Jul 29, 2003 04:39 PM
