Would a sealed box be Ok for this set up?
Old Oct 6, 2010 | 08:15 PM
kelviiv's Avatar
Default Would a sealed box be Ok for this set up?
Hello Everyone
I have purchased 2 HFi12D4 (Hifonics) subwoofers. 12". I am wondering if it would be Ok to use a sealed box. also i was wondering if anyone could recommend me a low budget amp ?
thank you
Old Oct 6, 2010 | 09:02 PM
kynetik's Avatar
Default Re: Would a sealed box be Ok for this set up?
What does the spec sheet say? Usually the Maxxsonics stuff has ported and sealed enclosure specs. Just build the box to the specs listed.
Maxxsonics stuff is fine for a budget build (Crunch, Autotek, Hifonics). Look up pricing on Amazon.
Old Oct 6, 2010 | 09:15 PM
kelviiv's Avatar
I have no clue what the spec sheet says. How much would it cost to build a box myself? I'm not really familiar with cutting, etc
Old Oct 7, 2010 | 08:27 AM
edzy's Avatar
ported...
Old Oct 7, 2010 | 10:17 AM
mhart's Avatar
a sheet of 3/4" mdf is around $30, then you need screws and good wood glue, so maybe $50-$60 to build a box yourself.
Old Oct 7, 2010 | 10:18 AM
mhart's Avatar
Subwoofer Specifications
Subwoofer Size 12"
Subwoofer Design Round / Circle
Main Cone Color Black
Voice Coil(s) Dual
Impedance (per voice coil) 4 ohms
Peak Power Handling 600 watts
RMS Power Handling 300 watts
Woofer Composition Injection Molded Polypropylene (IMPP)
Woofer Surround Rubber
Minimum Sealed Box Volume 1.25 cubic feet
Maximum Sealed Box Volume 2.15 cubic feet
Minimum Ported Box Volume 1.75 cubic feet
Maximum Ported Box Volume 2.5 cubic feet
Sensitivity 88 dB
Frequency Response N/A
Xmax (millimeters) 11 mm
Top Mount Depth 5-3/4"
Shallow Mount Installation No
Cutout Diameter N/A
Recommended Enclosure Type Ported / Vented
Sealed
Subwoofer Grille No
Re-Cone Kit Available No
Old Oct 7, 2010 | 10:20 AM
mhart's Avatar
with a rms of 300 watts and a peak of 600 watts, i'd look for an amp that makes 600-800 watts at either 1 ohm or 4 ohm.
Old Oct 7, 2010 | 11:08 AM
edzy's Avatar
800 is more than double the power.
Old Oct 7, 2010 | 02:09 PM
mhart's Avatar
he has 2 subs.
Old Oct 7, 2010 | 02:35 PM
edzy's Avatar
ah, thought he had 1
mitsuman
Audio / Security / Video
13
Dec 2, 2007 03:37 PM
4doorex
May 27, 2005 04:03 PM
jordan-boxer
Apr 10, 2004 02:28 PM
slowestcivicever
Jul 18, 2002 05:49 AM
