does abs light come on when key is turn over
i bought my teg 2months ago . i just notice that the abs light never comes on? is that suppose to be normal? or should it turn on for a sec or two after you turn the car all the way over.
i already check the bulb and its working
hmm wtf
abs works i think. i can hear it clunking when i slam on the brakes on wet roads.
what will make the abs light not come out . other then a missing or busted bulb? i checked the abs fuse already and its all there.
it doesnt come on when i pull the big plug on the abs unit.
i looked at the trace on the light bulb. doesnt look like it was cut or burnt
Pretty much all lights should come on when vehicle is started since most components do a self-check.
Unsure why it's not coming on. Try a different bulb. The circuit to the bulb could be open possibly.
Put your hand on the abs unit as it powers up, when you turn the key on, and see that it runs. Still not sure whether it is abs system or just the light. My light is on if I pull the fuse, and goes it off and the unit powers if the fuse is in.
the light works since i placed it in another socket. im guessing the cluster circuit trace must be broken somewhere
