Minnesota (Twin Cities)Ported and Polished GSR head for Ls Vtec
Located in the Twin Cities area, Mn
Have an OBD-1 GSR head complete with IM, TB, sensors and hondata heat shield. The head is ported and polished by headwerks in Bloomington, mn and it comes drilled, tapped, and plugged for an lsvtec setup. Can be returned back to non- lsvtec easily though. It had GSR cams and brand new valves and valve springs. zero miles since build up. Head should flow awesome. Looks great. Getting out of the game. Only things that are missing are the cam gears, fuel injectors, and valve cover I think. Email me or call with questions. I have and obd1 distrubutor, a hand command chipped obd1 ecu, the Ls Vtec oil line kit and OBD1 wiring harness that I will include for extra if you need them. We can work out a deal. Pretty much everything you need to go OBD1 DOHC VTEC
$650
Let me know...... 612- seven zero three-four one six nine
Robbie
$650
Robbie
