Which heater hose? 92 DA with B18C
On the firewall the upper heater core hose is leaking, what heater hose do I buy? The DA one is much to short/small, do I buy the one made for a DC? Any input appreciated, loosing a lot of coolant.
Why not just pick up some bulk heater hose of the correct inside diameter and cut it to length.94
Thank you - next question: is the off-the-shelf DIY coolant flush procedure a good idea? Is the t-valve which comes with the kit (and presumably meant to become a permanent addition to the hose, at least until the hose is replaced) going to become a leaky problem? Thank you in advance for your thoughts
