FS: Complete Integra LS parts car with GSR swap still inside! $1,900
Looking to unload this car with the GSR swap still inside. 129K on the motor & Tranny, 168k on the body. LS body. The head was completely rebuilt to stock about 9k ago with new valves, timing belt, water pump, belts, seals, tensioner, headgasket. You haul away or I can have someone tow it away at your expense. It does also come with p72 OBD1 ECU unchipped, DC Headers, & the distributor. TITLE IN HAND!
Looking to get $1,900 O.B.O for everything. If you would like the swap by itself I can take it out. Let me know.
Text or call me at 951-271-2689. You are better off texting me since I can't answer phone calls at work during the day time. Thank you
[IMG]
[/IMG]
[IMG]
[/IMG]
Does it crank over and run? I assume someone has to bring steelies or drag it on a flat bed lol
Sorry, not looking to part unless someone wants to buy the swap. I forgot to mention that the shell is no good. It has frame damage. Its only good for parts. It does crank over but I have to plug in the distributor and ECU back in.
oo9o9xaznoo
Jan 23, 2011 09:08 PM
eg6sir-s
May 26, 2004 11:26 AM
