Wiring/Diagram Help
Well I'm in the process of getting the car up and running and I got the wire harness back from a local shop. They gave me directions on what to do but with out the harness diagrams I'm screwed....... But Ill post exactly what this piece of yellow paper says.. (Note: I have a DX Have to set up for multi point)
(This is exactly what he wrote on paper)
Ef Ecu Plug
1. Move pin C1 to B10
2.Move pin C2 to b12
3. Connect blue with green stripe to C1 pin on the ecu plug
4. Connect the blue with yellow stripe to C2 pin on the ecu plug
5.Connect the red wire to the A3 pin, old wire no longer used
6. Connect the yellow wire to the A7, old wire no longer used
Heres where I get lossed, does he mean tap the jumper or splice it???
To the OBD2A ecu plugs
1. Connect the red with blue stripe wire to the D6 pin on the obd2a ecu plug
2. Connect the green with yellow stripe to the A8 pin on the obd2a ecu plug
3. Connect the black with white stripe to A6 pin on the obd2a ecu plug
4. Connect the white wire to the D7 pin on the obd2a ecu plug
5. Tap in The yellow with black stripe to the A11 pin on the obd2a ecu plug (DO NOT CUT EXISTING WIRE)
6.Tap in The dark green wire to the D11 pin on the obd2a ecu plug (DO NOT CUT EXISTING WIRE)
Thats all I got so some diagrams would help a lot guys. Thanks for the input in advance.
Ef Ecu Plug
When he says "tap in" the only thing that I can think of would be to splice into the wire, or de-pin that connection, get a new pin, and actually crimp them in the pin together. Just out of curiosity you had them do what to the harness? How come they couldnt finish this part for you? What you really need are just pictures of the wiring diagrams which I don't have on hand. I'd be willing to bet though that someone has posted them up in the FAQs. However, i'm not a nice enough guy to go searching for you
vinasity
Feb 8, 2005 06:07 AM
For the lead. And posting the same thing I basically posted??
