Transmission & Drivetrain Gearboxes, Differentials, Clutches
stock z6 trans rebuild for a friend. need syncros and.....
Old Oct 5, 2010 | 06:10 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default stock z6 trans rebuild for a friend. need syncros and.....
the dealer wont split them from the clusters. i need 2-3-4. havent talked to y friend that gets gear speed yet, but even then i cant get 2nd (or atleast i couldnt whe my b set)
i just need the syncros, input brg, seal and axle seals.
not a wtb, just tell me where i can get em.
thanks everyone.
Old Oct 5, 2010 | 06:45 PM
Aquafina's Avatar
Default Re: stock z6 trans rebuild for a friend. need syncros and.....
You can get a 3/4, 3/4/5, or 1-5 from me or Synchrotech.
Old Oct 5, 2010 | 06:52 PM
Mr. Badwrench
you got pm
thanks.
Old Oct 9, 2010 | 12:27 AM
Hybrid96EK's Avatar
If you are trying to address a grinding issue, you will most likely need to replace more then the brass synchro itself. Might want to inspect the collar real well also. The teeth get rounded and will require replacement if this is the case. Also check the dog teeth on the gears for rounding. Just FYI if you didn't know. Lots of people seem to think just the syhcro itself will solve grinding issues... this just isn't the case.
Blue_eg95
Mar 6, 2010 06:19 AM
I spy PSI
Honda S2000
Feb 8, 2010 03:09 PM
AshleyJEHS
Honda Civic (2001 - 2005)
Feb 3, 2008 08:24 AM
dohcdelsol93
Jul 6, 2007 03:19 AM
Cuong-nutz
May 5, 2005 10:26 PM
