About to install Toda header
I was just curious as to what people have used after installation to wipe down the header. I am very scared of leaving any type of residue after the installation. I really hope it comes out flawless. Thanx in advance
Make sure you use gloves to install the header.
Once that is done, with the car jacked, spray it down with brake cleaner.
Use the microfiber towels to wipe it off and it will remove any fingerprints.
Just make sure you DONT start the car up after installation. If you do not use gloves, the oil from your fingers will get on the header, and the intense heat will make those fingerprints even worse and harder to remove.
thats my advice to you.
Got it on yesterday. Wiped it down like a million times an still got residual streaks that showed up today : (
The weird thing about is i popped the hood this morning an it looked fine. Then i went somewhere an decided to check it again an there they were. I hope there's a way to get the streaks off.
if you're just after hp there are cheaper ways to go about it.
