checking tranny fluid
no check it with the car off and warmed up to operating temperature on level ground (i realize this is not for an accord but its the same, just check your owners manual to confirm)
http://techinfo.honda.com/rjanisis/p...404O00149B.pdf
If its for an Auto, check it at:
-normal operating temperature
-level surface ground
-in the recommended gear depending on the manufacturer; "Park" I assume for Hondas.
From what I understand, you can have it on or off, but it definitely helps to have it at operating temperature AND on level ground.
So do what you want as far as that goes.
NerfGunner420
Sep 27, 2014 12:02 AM
stevescivic
Feb 28, 2007 03:44 PM
GdmLaz
21
Mar 10, 2005 12:50 PM
