92 CB vs 94 CD PART INTERCHANGE
I have a 92 EX CB7 and I needs to get some parts for it. I found a chic that is parting out 94 CD sedan. Does anyone know if the Alternator, AC Condensor, AC Lines (from the compresser to the frame rail), PS cooler & lines, from the 94 Accord will bolt to my 92 Accord.
92 motor F22A
94 motor F22B
both non-vtec, 5 spd
92 motor F22A
94 motor F22B
I know the alternator is the same from 1990 to 1997 on all 2.2L engines, fits the acura CL as well.
The AC condensor should be different, considering the front of the CB and CD are different, so therefore... lines are very likely to be different as well.
I kinda thought the same things but I figured it's a honda it's gotta fit...what would you think the chances are on the condensor fitting???? I'll worry about the lines later...
Ok cool, I should have thought about that!!! Do you or anyone else know if the CD5 compresser will bolt up on the CB7 motor??? Then the condensor & lines should work, right??
Dude I dont think your understanding what Im saying. Will the CD AC compresser bolt up? If so I shouldn't have problems with the CD AC condensor & lines bolting up....
No offence but I can get all that above plus the CD5 side skirts, & power steering cooler for $100.00. Thanks anyways!!!!!
thewrai6th
Jan 9, 2008 11:56 AM
4DRPIMPIN
Sep 9, 2007 10:47 AM
