Suspension & Brakes Theory, alignment, spring rates....
Daily Driving alignment specs?
Old Oct 5, 2010 | 05:45 AM
dudee's Avatar
Default Daily Driving alignment specs?
hi Folks ,
so i have a 98 civic coupe some what low and daily the car now , what are the best ideal alignment specs ?? i also have a camber kit up front and im running 205 45 16 on a 16x7 wheel on Skunk2 coilovers . Would factory specs be the best for this setup? Not really sure what i am looking for just to daily drive the car and not have camber wear
Old Oct 5, 2010 | 07:34 AM
96hb's Avatar
Default Re: Daily Driving alignment specs?
The main thing is to have the toe set as close to 0 as possible. Having a little negative camber will not wear your tires out excessively fast. My car has about -2.5 degrees of camber on the front and about -1.9 on the rear and my last set of tires lasted me 2.5 years and around 40,000 miles.
Old Oct 6, 2010 | 05:06 PM
FlewByU352's Avatar
there was a thread on this not too long ago. After gathering all the info I figured out to do this:
Front:
-1° camber
0° toe
Rear:
-.5° camber
.02° toe in (high speed stability)
Old Oct 7, 2010 | 05:51 AM
MrBAIN3's Avatar
Factory alignment specs are probably your best bet. Try not exceed -.5 degrees camber either front or rear. Sometimes this is hard depending on how low your car is. Toe adjustments being wrong are what usually wear tires out the most. Next to driving habits.
Old Oct 7, 2010 | 08:42 AM
unusual71's Avatar
2 or 3° camber won't really effect tire wear very much however like mentioned too much toe in or out will. I set my cars up with a touch of toe out in the front and a touch of toe in for the rear. i like it at 1/8th out up front and 1/16th in for rear.
Old Oct 10, 2010 | 03:20 PM
GTRmaster's Avatar
you dont really need 3° of camber for the steet
punxsk8r555
Suspension & Brakes
Aug 13, 2010 04:27 AM
aSDthing
Suspension & Brakes
Nov 27, 2007 06:32 AM
deviant1
Dec 10, 2003 07:25 AM
Racerage1
Jun 14, 2003 11:33 PM
alfaaay
Mar 21, 2003 06:30 PM
