please help i need answers!!
Old Oct 4, 2010 | 11:33 PM
mashitup's Avatar
Default please help i need answers!!
so i have a d15b7 and just bought a y8 head i need to know what head studs and timing belt to use for this also with a p28 i would need to run a obd-1 dizzy correct answers or links will be greatly appreciated
Old Oct 5, 2010 | 04:26 AM
Fo-Do Fanatic's Avatar
Default Re: please help i need answers!!
Whenever doing a mini me swap, I've always been told to match the head studs and timing belt to the head you're using or going to run.
Your ECU needs to match the OBD of the dizzy. I.E OBD0 dizzy/ecu OBD1 dizzy/ecu and etc...
Old Oct 5, 2010 | 10:33 AM
mashitup's Avatar
alright and ive also heard that you can use the old studs but you need a certain one for the corner under the vtec selinoid or else it wons seat properly and leak is this true?
Old Oct 5, 2010 | 10:57 AM
90efhatch's Avatar
The engine leaks in that corner due to the cylinder head or block not being flat. Headstuds are a certain length for a reason you should keep them all the same.
Old Oct 5, 2010 | 11:01 AM
No. One of the headstuds for the vtec single cams are longer. And it's the one on that side.
Vtec and Non-Vtec head studs are different.
traynemusic
Feb 4, 2018 08:21 AM
yackkie_k
12
Apr 21, 2007 06:06 PM
alwaysared
Apr 7, 2007 11:37 PM
raneys-rex
May 12, 2006 07:15 PM
ss20gsr
Feb 7, 2004 08:20 PM
