A few Last Wires to finish the GSR
Old Oct 4, 2010 | 07:52 PM
89LSED's Avatar
Default A few Last Wires to finish the GSR
I got the GSR installed this weekend.
And I have a few things to finish wiring up, but it runs for now.
Here is my wired setup.
94 GSR Motor w/ Stock Intake Manifold
91 LS exhaust Manifold
Pr-4 ECU
Modified Pr-4 OBD-0 Dizzy
OBD-0 Injectors with Resistor Box
1 Wire O2 Sensor
NOW BEFORE PEOPLE FREAK OUT! THERE IS A METHOD TO MY MADNESS!
I did not have the proper engine harness to accept my OBD-1 Dizzy, I did not have a 4 wire O2, and im broke. HAHA
I needed to get the car running this weekend so i did what i had to do.
(Plus im still trying to break in the motor. So with a lower RPM limiter, and with no vtec, then i wont be as tempted to go over my 4000 rpm rule)
Now I have everything hooked up and running except the vacuum purge solenoid above the map sensor, and the black box under the manifold.
Now the wireing harness i am running had a 4 pin plug that plugged into the 2 solenoids on my LS, Do i just split those apart to run the GSR?
I hope my question makes sence.
Thanks again
Old Oct 4, 2010 | 08:10 PM
JeffBro's Avatar
Default Re: A few Last Wires to finish the GSR
Dude I hope you don't even drive it for the sake of your poor motor. Its not gonna run good at all with pr4 ecu. Just save up a little bit of cash for obd1 conversion. all you need is the rywire ecu harness which is $100 & 4 wire O2 sensor. Thats all you need. You could find a used O2 sensor even. Wiring the dizzy is easy even if you don't have the plug you can solder it in just use the stock plugs from your old motor
Old Oct 4, 2010 | 08:15 PM
JeffBro's Avatar
btw you don't need either of those things you mentioned because you don't even have the right ecu so its not gonna matter. The black box is for the IAB's but you don't have a P72 so it doesn't matter.
Old Oct 4, 2010 | 08:28 PM
89LSED's Avatar
Haha, I knew I would get reactions like this.
The car runs pefectly fine as it sits right now. There is nothing really differient about the pr4/p72 ecu mapping.
It will be just fine as is for a little while. Im not hot rodding it around, keeping it under 3500-4000 rpm.
ummda9guy
Jan 29, 2011 05:33 PM
Olivemyhonda
18
Mar 12, 2008 07:22 PM
Olivemyhonda
Jan 26, 2007 01:31 PM
zenon8890
May 5, 2006 01:20 PM
Another B16
Jul 7, 2004 06:17 AM
