Mechanized Paint Removal - Power Washer, Media Blaster, Etc (Questions)
Old Oct 4, 2010 | 04:58 PM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Mechanized Paint Removal - Power Washer, Media Blaster, Etc (Questions)
I now have a car with a meagerly done Rustoleum paint job, and some rattle can touch ups. Blah! Black was the color, so it held up poorly on top of that.
Options?
Rustoleum 'White' it (with black trim), as having the strongest pigment, White might turn out ok?
or... can I use a power washer, power sander, media blaster, or some other kind of way where I could strip the car with some decent speed? What is the best way besides hand sanding, and tears...
Old Oct 4, 2010 | 05:04 PM
DC2.2_GSR's Avatar
Default Re: Mechanized Paint Removal - Power Washer, Media Blaster, Etc (Questions)
Options?
soda blasting or mechanically with a DA sander.
Old Oct 4, 2010 | 05:07 PM
pm sent, I see you are near Philadelphia.
Old Oct 4, 2010 | 05:53 PM
DC2.2_GSR's Avatar
Philadelphia is where I tell people I'm located because when you try to explain to people that you're 40 miles NW of Philly, up Rt. 76W to 422W to 100N in a little town called Bechtelsville people usually just stare blankly. That's why there's a map on our website. lol. You've got a PM back.
Old Oct 5, 2010 | 10:04 AM
What about a power washer? I've seen it strip paint before (off of a car... by accident). Thoughts?
Old Oct 6, 2010 | 05:41 AM
Also, what of
http://www.amazon.com/Porter-Cable-7.../dp/B002654I46
Would that be good as a sander for paint removal?
Old Oct 6, 2010 | 07:22 AM
DC2.2_GSR's Avatar
No, there's no way that you could strip paint with a power washer. you could damage the paint and dent the surface with enough pressure but there's no way to completely strip a car's paint with water pressure.
Also, what of
no, that's a polisher. you need a DA (dual action) sander. a painter's DA is meant for higher grits and prepping cars for paint so it's less aggressive and easier to work with. a body guy's DA is usually larger and runs much more aggressively in order to remove material. it's a better investment to buy a painter's style DA because you can't always get a finer result from a body DA, but you can always put extremely rough DA paper on the painter's DA and remove lots of material that way. the painter's style is more versatile.
here's a SnapOn DA sander that I use for all paint prepping
http://buy1.snapon.com/catalog/item....re&dir=catalog
i also use this Hutchins for rougher work and removing material.
http://www.google.com/products/catal...d=0CC0Q8wIwAw#
Old Oct 6, 2010 | 08:22 AM
ej1 rep's Avatar
so your going to strip the car and re-rustoleum it? wierd. anyways a DA and some elbow grease is your best bet.
As for painting it white rustoleum, I did it to my car and thought it was the ****. That was untill I pulled up to a car identical to mine with a OEM frost white paintjob and it mine looked like complete *****. Plus the paint was able to be scratched off with my fingernail. (Yes I did everything correctly)
Its your car so do what you will, just my .02 cents.
Old Oct 6, 2010 | 09:03 AM
ej. I am either going to re-rusto it white which may work okay, or take it all down and get a quick single stage or some low level automotive paint... in reality, paint is last, the car was beat on by a thief and has all sorts of dents that I need to work out first.
Sinner
Paint and Body
Jan 29, 2008 08:44 AM
redrusch
Paint and Body
Aug 29, 2007 08:03 AM
TurboBumblBee
Feb 22, 2002 10:33 PM
