LS Block P30 pistons LS Vtec Twin Cities MN
Going up again.
PRICE LOWERED - $300 FIRM NO LOWER GREAT DEAL
Located near Twin Cities, MN
B18a LS Short block from DA's has the knock sensor
Cylinders honed
Has JDM B16 P30 pistons pressed on LS rods
ARP rod bolts
ACL bearings
New OEM Vtec oil pump
vtec water pump
new gsr timing belt
All assembled just needs a vtec head.
PM for questions
Cylinders honed
ARP rod bolts
ACL bearings
vtec water pump
new gsr timing belt
PM for questions
Pics are up, pistons and arp rod bolts were pressed in by a shop and no I do not have the receipt no more. The block was assembled by me per haynes manual. If you wish to reassemble it you may do so after it is yours.
It has been sitting for a year now, probably has some surface rust.
