Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
01 LX 2nd Gear Tranny Problem
Old Oct 4, 2010 | 05:30 AM
DJ4Jesus77's Avatar
Default 01 LX 2nd Gear Tranny Problem
I'm not the most knowledgeable when it comes to transmissions, but within the last 2 months I've been having a problem with my 2nd gear. Whenever I'm turning in 2nd, it'll slip completely out of gear. However the odd part is that its only in a turn. In a straight away I dont have this problem. Its embarrasing because it eithe slips out or it creates a faint grinding sound, of course as this happens I engage the clutch and place it back into 2nd. Any help would greatly be appreciated. I'm not sure if this is a common problem with the transmission. Also I'm wondering about how much this would cost to be fixed.
Old Oct 4, 2010 | 08:36 PM
zztrent's Avatar
Default Re: 01 LX 2nd Gear Tranny Problem
wow that sounds really weird....
Old Oct 5, 2010 | 04:59 PM
DJ4Jesus77's Avatar
Its just been really odd. Thought i might take a shot on here and see if anyone would know, before I thought about taking it to a shop and getting it looked at.
Old Oct 5, 2010 | 07:44 PM
zztrent's Avatar
Have you tried replacing the transmission fluid? Some times that fixes odd problems. I have never heard of that happening on any manual car before. Hopefully the garage will be able to figure it out. Maybe it's something simple.
Old Oct 8, 2010 | 11:33 AM
tws03cl's Avatar
Yep, it happens in my car! No idea what the cause is though. Just wanted to let you know you're not alone.
Old Oct 8, 2010 | 12:11 PM
Targa250R's Avatar
be professional
The first thing to check when the transmission pops out of gear is the fluid level. Remove the fill plug and stick a finger in there to check the fluid level. It should be full up to the fill hole, to the point of almost spilling back out. If it is not full, drain and refill the fluid. Even if it is full, you might as well drain and refill it anyway since you're already in there.
Use genuine Honda MTF or an equivalent lightweight FWD manual transmission oil such as GM Synchromesh, Pennzoil Synchromesh, Redline MTL, or BG Syncro-Shift.
Do not use standard gear lube such as 75W-80 or 80W-90 - it will ruin the bearings in the transmission.
Old Oct 8, 2010 | 02:33 PM
DJ4Jesus77's Avatar
Thanks for the advice man. Also good to know Im not alone on this. lol
I'll check the level. Kinda odd for it to be low I just had the the Transmission drained and refilled when I had my timing belt changed this spring.
Old Oct 8, 2010 | 03:58 PM
Targa250R's Avatar
be professional
Who changed the fluid and what did they fill it with?
Old Oct 8, 2010 | 04:40 PM
Pothole987's Avatar
i used 10w30 oil in my transmission. its only a dd but apparently thats alll that was needed.
i would drain and put fresh fluid in.
Old Oct 8, 2010 | 04:48 PM
Targa250R's Avatar
be professional
Standard 10W-30 engine oil works, but shift quality is poor. Honda MTF noticeably smooths shifting action compared to engine oil.
Old Oct 8, 2010 | 08:57 PM
B18B1-Crx's Avatar
its something to do with your differential, Is your tranny stock or swapped?
JunIntegra
Honda S2000
19
Oct 20, 2008 10:56 AM
Type_Rb18c5r
Mar 12, 2008 03:43 PM
VTECcnIT
Feb 25, 2006 12:12 PM
2.3vtec
Sep 7, 2005 11:03 AM
soundcheck187
Jul 15, 2005 04:49 PM
