Honda S2000 Honda S2000
how much do stock nsx wheels go for?
Old Sep 19, 2002 | 12:24 PM
rudeS2k's Avatar
Default how much do stock nsx wheels go for?
wondering the cost for a set of nsx wheels...like the 98 and above..the multi spoked ones..will only the front fit on ITRs?..curious
Old Sep 19, 2002 | 12:49 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: how much do stock nsx wheels go for? (98ITR0884)
There are too many differences to fit them onto the ITR very easily. The offset is different (55 mm NSX front, 50 mm ITR), and the center bore (size of the hole in the middle) is different (70 mm vs 64 mm) so you would need to fabricate some hubcentric rings. Plus, I know the 15" ones won't clear the ITR suspension unless you use spacers, and I'm not sure whether or not the 16" ones will. (The NSX rear wheels are even worse; although the center bore is the same, the offset is 60 mm.) And they're expensive (discount prices are $700 per wheel new; sets of four typically sell for $1500-2000, depending on condition, or more if they have tires on them). All in all, not worth it.
[Modified by nsxtasy, 10:40 PM 10/28/2002]
Old Sep 19, 2002 | 12:51 PM
rudeS2k's Avatar
Default Re: how much do stock nsx wheels go for? (nsxtasy)
hey thanks..for the 411
Old Sep 19, 2002 | 02:24 PM
nsxtasy's Avatar
H-T Order of Merit
No prob.
I wanted to use some extra NSX wheels I had for my ITR - even went so far as to try getting hubcentric rings at the Tire Rack - but eventually gave up and got some extra ITR wheels (which are relatively easy to come by).
Old Oct 28, 2002 | 06:33 PM
migs's Avatar
So the 16x7 55 offset wont fit under an R eh? Not even if you get 205-45-16 tires?
Old Oct 28, 2002 | 07:42 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: how much do stock nsx wheels go for? (Migs)
The tires might fit, but what are you going to do about fabricating hubcentric rings? And why would you be going to all this trouble, considering how expensive the NSX wheels are?
Old Oct 28, 2002 | 07:59 PM
Dirty GS-R's Avatar
New User
ask BabyNSX from the itr forum. he's done this with the 4 nsx fronts and i'm sure he'll help you out.
Old Oct 28, 2002 | 08:15 PM
Auraraptor's Avatar
Default Re: how much do stock nsx wheels go for? (Dirty GS-R)
NSX 7 spoke fronts fit on 97+ preludes right? I read that somewhere...
Old Oct 28, 2002 | 08:57 PM
hired gun's Avatar
They are rather cheap around here where I live. Ask MIGS he has my book with ALL the prices!!!
Old Oct 31, 2002 | 10:37 AM
migs's Avatar
Default Re: how much do stock nsx wheels go for? (hired gun)
I can get a BRAND NEW set of 16x7 NSX wheels (4 front) and NEW tires for a smokin price. So dont go assuming that they are "expensive" just yet.
I understand the whole hubcentric ring but I remember I had a set of Desmond Regamasters and Dave @ R&D said we didnt have to use them. The hub of the wheel didnt even match up with the hub on the rotor.
Old Oct 31, 2002 | 11:07 AM
nsxtasy's Avatar
H-T Order of Merit
New wheels alone, without tires but with center caps, are $653 each at Dali Racing, which generally has the best discounts around. If you can get them for much less than that, I'd love to find out where, and what some of their other prices are.
Then Dave doesn't know jack sh*t.
Using wheels with larger bore holes without hubcentric rings is a very, very bad idea. Go here and scroll down to the section that says "What About Hub Rings / Adapters / Spacers?".
tnkw
Feb 8, 2009 09:50 AM
ej_b16a
Nov 28, 2007 04:43 PM
Freeltec
Jan 7, 2006 03:10 PM
EEK
Apr 20, 2005 12:44 PM
CrewChiefDoug
Nov 26, 2001 03:36 PM
