Will 15x5.5 +45 fit a 1993 integra rs?
Like the title says
Will I have any trouble with the fitment of 15x5.5 ET45 wheels on a 1993 Integra RS?
these wheels to be specific: http://img.photobucket.com/albums/v3...2/DSCF5057.jpg
You should find out what the hub bore is on those wheels. The width and offset you mentioned should be fine on a DA Integra. Your hub OD is 56.1mm on an Integra so you should make sure the hub bore on those wheels is at least that large.
thanks OC DC2, Gekko, and nsxtasy.
I'm gonna pick these wheels up this weekend if all is well... nice upgrade from the stock 14" wheels, and they're only 12 lbs each... not bad for 70$ each *shrug*
