Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
5 lug conversion
Old Oct 3, 2010 | 12:36 AM
d17beast's Avatar
Default 5 lug conversion
hey, i just recently did a 5 lug conversion from a base model rsx. i used the rsx front suspention/shock with an ebach lowing spring. my car is jacked up looking like as if it wasnt lowered a bit. can anyone help me out on this?
Old Oct 3, 2010 | 04:15 AM
toyomatt84's Avatar
Sanji
Default Re: 5 lug conversion
You put the rear springs on the front, per chance?
Old Oct 3, 2010 | 10:36 AM
J(ef)F's Avatar
Its pretty hard to mix the springs up,the fronts are the larger diameter and the rears are the smaller.
Old Oct 3, 2010 | 10:38 AM
J(ef)F's Avatar
How much do your eibach springs say they are supposed to lower the car?
Old Oct 3, 2010 | 03:47 PM
Pothole987's Avatar
its still jacked up? that would be an issue.
Old Oct 4, 2010 | 01:02 AM
theineffable's Avatar
did you load the suspension before tightening the nuts and bolts? if you don't load the suspension first, you'll stress the bushings and the car will also sit higher...
Old Oct 8, 2010 | 06:44 PM
d17beast's Avatar
hmm you know what? my brother and i took a look at it. the lowering springs were already put onto the stock rsx shock strut, so we just installed it in the way it was so im not really sure whats up with the height. it rides really stiff as if i had coilovers. it sucks whenever im going over light bumps but taking corners is fine. im not flying through corners or anything but i mean, i can definetly tell a difference because its pretty stiff.
i dont know much about the em2 suspensions with the rsx stuff, but do you know if my neuspeed springs would fit onto the RSX stock shocks/struts?
Old Oct 8, 2010 | 07:48 PM
ourbloodykisses's Avatar
well stock dc5 spring rates are stronger than stock em2 spring rates, so it could be that they arent soft enough to even out the ride height as before, but it should be noticeable at all.
Old Oct 12, 2010 | 04:47 AM
Bxjay16's Avatar
how much did u pay for your conversion, i cant seem to find it base model
Old Oct 14, 2010 | 12:50 AM
i'm not talking about spring preload...
what i meant is that you need to put a load on the entire suspension so that all the control arms are at their resting angle before the nuts/bolts are tightened. also, is it really that stiff or is it just bouncy? there's a difference
as for stiffness, DC5 stock suspension is approx twice as stiff as stock civic suspension.
Old Oct 16, 2010 | 03:50 AM
fventura03's Avatar
rsx springs on em2 sit higher because the car is lighter... eibach springs are only a 1" drop, so thats your problem, get lower springs.
Old Oct 16, 2010 | 06:52 AM
d17beast's Avatar
bought it together with a complete k20a3 swap.
Old Oct 16, 2010 | 06:55 AM
d17beast's Avatar
thanks for the info. the conversion came off a wrecked base model rsx. the top of the struts were not straight, it was a little bent but we got it to fit properly. and i didnt like the way it sat so at the moment, i am using the stock civic struts and shocks from the em2. i know the two bolts holding the brake to the shock is a different size but it still holds.
its probably dangerous but it rides fine since im not driving like an idiot. its just temporary. but thanks for all the help.
Old Oct 16, 2010 | 07:01 AM
Harlowe's Avatar
Function>Fashion
I ran my 01 shocks on rsx knuckles with bigger holes for well over a year with no problems.
j0KeRzWilD
Mar 19, 2009 08:44 AM
Jibin
Jul 25, 2008 08:14 AM
naeghatch
Suspension & Brakes
Oct 23, 2007 06:31 PM
hcridesi
Mid-Atlantic (Sales)
Aug 28, 2006 12:28 PM
