URGENT: Piston to wall clearance: YCP 82mm on B18C
I am searching all around but I can't find the piston to wall clearance of the following pistons:
Piston details:
-YCP PCT Civic Type R pistons 82mm
-T-6 heat treated (Semi forged)
-AC8A grade aluminum (Stronger than regular OEM pistons)
-Coated
Honda specs:
0.01mm - 0.04mm (0.0004inch - 0.0016inch)
service limit: 0.05mm (0.002inch)
What P2W clearance should I go for? As far as I know this piston's material expands less than the regular cast/oem piston. Can I go with the honda spec.?
The engine won't be turbo or a 10k rpm motor, so I think that I don't have to go wide on the clearance.
I need this information ASAP.
Thanks.
Piston details:
-Coated
Honda specs:
Thanks.
E Town DSM
Jan 31, 2014 01:02 PM
95c1v1cs1
Jul 28, 2004 09:44 AM
