Temp Guage Fail
Old Oct 2, 2010 | 04:57 PM
joseph.ficarra's Avatar
Icon6 Temp Guage Fail
Hey guys, Im new here. Ive been lurking in the background trying to pick up the "culture" and now its time to tap your combined knowledge!
So Ive got a 91 CRX Si thats still running the D16. When I first bought the car everything minus the Tach worked. After a day or so, I noticed the Temp gauge went south on me. (Background, I let my wife drive it, and shes not exactly smooth on the clutch...) I figured something got shaken loose, but everything seems solid in the cluster. I repaired the Thermotime sensor on the block since the male end of the connector was in terrible shape, but that still didnt fix it. Im assuming the gauge it self works since it moves slightly when the ignition is turned to "on".
Give me any pointers on where to look next?
Old Oct 2, 2010 | 06:20 PM
raffaelli's Avatar
Default Re: Temp Guage Fail
Do you have continuity to ground and the cluster?
Old Oct 2, 2010 | 06:33 PM
GroundZer0 336's Avatar
check the coolant temp sensor? maybe the plug is a little messed up or corroded? its right under the distributor, with one male spade type plug....i think. pretty sure thats the sending unit for the gauge.
Old Oct 2, 2010 | 07:27 PM
That would be a good place to start. Im assuming the ground is fine, since the Fuel gauge and Speedo work, but you know what they say about assuming.
Truth be told, car electrical isnt my strong suit and this cars wiring harness is all kinds of hacked up and spliced. I'll check the ground and see what that brings up. Thanks for the idea!
Old Oct 2, 2010 | 07:29 PM
I spliced in a junkyard find plug, though I didnt change the sensor itself. The original plug was dirty and didnt "click" in properly so I was hoping that was the issue.
Old Oct 2, 2010 | 11:39 PM
hatchet_honda's Avatar
where did you get the term THERMOTIME SENSOR lol...well id try changing out the temp sensor itself..its ther 1 pin plug on the head below the dizzy.
Old Oct 3, 2010 | 07:04 AM
Actually, you just made me re-consult my manual which just pointed out my error! I replaced the plug on the thermosensor which is next to but not the temp gauge sending unit! Sometimes a little criticism does help! Now I'm off to check into that plug! Thanks!! :-)
dglassmyer
Apr 27, 2010 08:14 PM
zippakilla
Feb 21, 2009 11:02 AM
1991hb
Sep 27, 2007 06:10 PM
DaGlitch
Aug 18, 2007 08:20 PM
