d/b parts gsr ls dizzy
Old Oct 2, 2010 | 04:46 PM
khaledbuiltEF's Avatar
Default d/b parts gsr ls dizzy
call 407 928 9691 or 407 683 1490
1. d series thermostat with housin .10
2.d series aluminum header gasket. 7
3.jb1 rear speaker was an 90 crx 10
4. d series tensioner no bolt 7
5.d15 spark plug wires of 94 dx 10
6.d series timing belt used with less than 500 miles .10
7.d series aftermarket undercrank pully i have 2 you choose 30 each
8.d15-d16 oil pick up 7
9.d series motor mount still good 20
10. d series tranny mount 20
11.jdm d15b short rods has pistons on for free just askin 35 for all 4 rods
12.b series aftermarket flex tube 15
13.22o watt amp might work not sure 20
14.d15b crankshaft 55
15.obd1 gsr dizzy work come and test 1 problem is where you put the bolt on the left is half off still can use and put bolt nothing crazy still works great 65 no going less
16.obd1 ls integra dizzy works perfect new caps an rotor come test it 70
Old Oct 2, 2010 | 04:48 PM
Default Re: d/b parts gsr ls dizzy
bump need this **** gone
khaledbuiltEF
Nov 20, 2010 02:40 PM
khaledbuiltEF
Oct 3, 2010 09:05 PM
Vera
12
Nov 17, 2003 08:44 PM
