92 Engine Squeal
Old Oct 2, 2010 | 04:25 PM
cyclonedr's Avatar
Icon2 92 Engine Squeal
Hello all,
I went out for a hike this morning, and when I returned to my car and started it, I heard a squeal coming from the engine compartment. It hasn't had any trouble with squeals prior to this event. As I drove down the road, the squeal dissipated, but when I pulled up to stop sign, and then got going again as I shifted through 1st and 2nd it was noticeably loud, then dissipated again. When I got back, I left it running and popped the hood, and could hear a sort of squeal coming from the side opposite the timing belt, my original thought for what may be wrong. Not sure what's going on, not sure what could make a squeal from that side. I'm currently in college, so the car is parked for about a week at a time in between drives. Could something have happened while it was sitting? As a side note, would you recommend I leave the battery connected? Even though I don't drive that much, reliable transportation it sure nice!
Thanks for any help
Old Oct 2, 2010 | 05:07 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: 92 Engine Squeal
check your accessory (a/c, power steering, alternator) belt tension and adjust if it needs it
Old Oct 2, 2010 | 11:45 PM
Dannyvho's Avatar
x2: Do a test with the engine running at idle rpm: switch on all electric devices you can think of (headlight, rear window defroster, fog lights..). If the squealing sound gets louder then it is definately the alternator belt.
Leaving the car sit for a week with the battery connected should be no problem.
meadams314
10
Sep 20, 2010 09:48 PM
Jen GS
Apr 29, 2010 03:38 PM
1992hludesi
Oct 10, 2005 05:37 AM
preciouscez
Jan 1, 2005 05:39 PM
GQ Cowboy
Jan 25, 2002 01:17 PM
