NEED HELP FAST GUYS!!!!!!!!!!!!!!
Old Sep 19, 2002 | 12:08 PM
71 mgb's Avatar
Default NEED HELP FAST GUYS!!!!!!!!!!!!!!
i have a 85 crx, the valve cover gets extremly hot...... i dont know whats wrong the temp gage stays at a good point but when i open the hood its like a heat wave off the valve cover..... what could be wrong?
thanks
Old Sep 19, 2002 | 12:17 PM
dustin's Avatar
Default Re: NEED HELP FAST GUYS!!!!!!!!!!!!!! (71 mgb)
Engines are hot..
Old Sep 19, 2002 | 12:24 PM
Home Skillet's Avatar
thanks
you can't be serious? does your valve cover have heat sinks?
Old Sep 19, 2002 | 12:31 PM
93eg-EKhybrid's Avatar
Default Re: NEED HELP FAST GUYS!!!!!!!!!!!!!! (Home Skillet)
do you even know how a motor works? try touching various engines in all types of vehicles.........They will all be hot!
Old Sep 19, 2002 | 12:34 PM
Urban Business
Guest
Posts: n/a
Default Re: NEED HELP FAST GUYS!!!!!!!!!!!!!! (dustin)
Engines are hot..
and so am i
Old Sep 19, 2002 | 12:37 PM
71 mgb's Avatar
Default Re: NEED HELP FAST GUYS!!!!!!!!!!!!!! (89B16HB)
the vavle cover does not have heat sinks...... i already busted a cam becuase of it... it heated up my cam belt and made it skip teath and trow everything out of timeing. i bent 2 valves and boke the cam....... im not a idiot so dont tell me the engine is hot or **** like that... i was just wondering if anyone has ever herd of a problem like this before or if they know what it could be........ the valve cover is about at hot as the exhaust manifold.........
Old Sep 19, 2002 | 12:38 PM
Urban Business
Guest
Posts: n/a
im still hot
Old Sep 19, 2002 | 12:39 PM
dustin's Avatar
Is the cam seizing up in the cam holders? What do the bearing surfaces look like...
Old Sep 19, 2002 | 01:01 PM
big pete's Avatar
drop drop drop it likes it hot...........does the distributor get hot too??.....touch it and get back to me
Old Sep 19, 2002 | 01:43 PM
71 mgb's Avatar
Default Re: NEED HELP FAST GUYS!!!!!!!!!!!!!! (big pete)
ya man the distributor is hot as well.....
Old Sep 19, 2002 | 02:41 PM
71 mgb's Avatar
gey guys i was just thinkin could my head get hot form running to lean?
thanks
Old Sep 19, 2002 | 07:20 PM
Blaze45's Avatar
Brrraaaap!
yes, when you detonate the explosin inside your engine reaches 1600 degrees inside by the piston an spark plug. very bad.
Blaze
Old Sep 19, 2002 | 07:43 PM
Steve Berman's Avatar
I thought it was "drive drive drive it like its hot". Like a stolen car? Anyways, I suggest you hook up an external temp guage and check the temp. I have never heard of the head getting so hot that the timing belt jumps. dunno, im hot too
Old Sep 19, 2002 | 07:51 PM
89 CRX SI's Avatar
Default Re: NEED HELP FAST GUYS!!!!!!!!!!!!!! (Steve Berman)
thats why we live in canada just leave hood up overnight and let the snow poor in the close it.. solves the problem.
Old Sep 20, 2002 | 03:53 AM
Default Re: NEED HELP FAST GUYS!!!!!!!!!!!!!! (89 CRX SI)
is your halogen fluid low?
kodylive
Sep 30, 2012 01:15 AM
ChrisHinds
Paint and Body
Aug 25, 2008 11:22 AM
1 point 6
Nov 2, 2006 08:45 AM
skrigz
May 29, 2006 01:32 PM
mikeSONICGSR
Sep 9, 2002 08:33 AM
