best injectors for my set-up?
b16a head.
port&polished.
buddyclub spec III cams.
buddyclub retainers.
buddyclub valve springs.
skunk2 camgears.
hytech header
itr manifold/ str 68mm TB
b18c1 block.
ls crank/shot peened ls rods
ctr pistons.
Angel4768 is online now Report Post Edit/Delete Message
port&polished.
skunk2 camgears.
hytech header
b18c1 block.
ctr pistons.
yeah the car pulled and had allot of torque. but i still need to get it tunned do you know what rev limit would be safe for my setup i got an ls crank and iv'e been hearing you can't rev as high
You really need to know what you have under the hood before anyone can recomend anything.
first and probably easiest thing to do is take off the valve cover and have a look at the cams to see if the're legit. Next would be to lift off the head and have a look to see wat kind of block u have (if sleeved).. although if u do have in ctr pistons it would be standard 81mm bore.
you would be running very close to 13.0:1 compression with a set up like this, tuning and good octane gasoline would be a necessity.
about safe rev limit, IF it is a b18c1 block then u should have a girdle as well and i'd say it should be safe to rev to 9000 easily... cams would probably drop off power a good while be4 that though.
Angel4768
May 9, 2011 12:49 PM
Angel4768
Oct 8, 2010 01:19 PM
Angel4768
Sep 26, 2010 05:17 PM
Angel4768
Jul 19, 2010 09:38 PM
