Civic wago rt4wd question
hey all have a quick question about the rt4wd wago, well im planing on swaping a z6 into my wago that is 4wd and noticed that the 4wd tranny uses a half shaft while non 4wd tranny dont, also noticed the z6 doesnt have the bolt holes on the block for the haftshaft, so i was thinking in order to use the z6 id have to get a normal longer driver side axle from a normal d series, i no the axle spines are bigger but my questiuon is if anyone has swaped the splines off the 4wd axle to the longer d sieres axle? do you think that axle would be able to hold the extra torque of the 4wd? any input would be appectaited
