drilling the manifold
ok so i have a 89 hatch mpfi swapped, and i have a y8 manifold. can i drill a place for the intake air temp sensor or what should i do about it there isnt a place in the mainfold for it, and also i noticed the manifold blocks off some of the idle ports, so will i have an idling problem to...any posts will help
x2 i appreciate the help but i mean the idle ports in the tb there getting blocked by the manifold or thats what it looks like and im not sure if it will even idle
ok so i re-extended the wires for that so it should be able to go most anywhere in the intake pipe, but i really dont think this thing is going to run w/o a vaccum leak or something
not if u seal it properly. use some jb weld or just drill the hole so that its almost percise with the unit, then seal with some gasket maker if u want
My_EFsedan
17
Apr 18, 2010 09:46 PM
I Like Hondas
Jun 22, 2008 02:59 PM
jdmegcivic95
Aug 10, 2005 05:53 AM
