1995 Integra Trunk Leak ! NEEED HELP
I have water leaking into my trunk when it rains. All the water goes into my spare tire area . How would you get to your drain tubes? ive heard it could be multiple things ? need help asap please
that was my problem..
go to a store and buy some clear silicone and put a nice layer in between the tail light and the housing. but before you do that make sure its the tail light by hosing it down for a while. silicone only costed like $3.00
a little late, but yes very common Honda problem, just about every honda I've owned or heard about from the 80's to atleast the late 90's has had problems with the tail light gaskets leaking. And Ive found the easiest solution is to silicone them as mentioned, how ever I usually put silicone on both sides of the gasket, let it dry, then install so its just more of a gasket repair.
TurboGS-R
Apr 2, 2006 10:32 PM
lshobo
Jan 9, 2002 11:19 PM
