Bubble Wheel Balancers? Do they work?
Found one @ the local Harbor Frieght for cheap and was wondering if anybody else on here uses them? Do they work? And how do they compare to the electronic ones? Any type of information will be greatly appreciated. Thanks!!
http://www.bubblebalancer.com
I don't understand why anyone would bother, unless you have a shop. Most of the time, you only need to balance tires when you're mounting/dismounting them, and you'd have to go through an awful lot of tires to justify the cost to buy mounting/dismounting and balancing machines.
You have to look at the ROI in such a purchase. If you plan on M&B tires and wheels for the neighborhood for a fee, go for it. Otherwise, how many times are you going to use it, realistically? If you have the room, great, because you're going to need it.
yes im going planning to start charging people for it.. so does it work? that is my question.
Stickied at the top of this forum is a topic:
Forum Rules and FAQ - READ BEFORE POSTING
It says:
It says:
Originally Posted by Forum Rules and FAQ - READ BEFORE POSTING
Rules
7. Bump once and if you still don't get the info you're looking for just let it die, don't bump it again. If you bump the topic a second time, the topic will be locked and you will lose points. Think about this - this means that if you use your single bump on your topic after an hour, when it's still at or near the top of the forum topic list anyway, it will be wasted when it doesn't accomplish anything for you.
Katies98ITR
Oct 26, 2004 05:37 PM
