alternator isn't charging the battery.
Old Oct 1, 2010 | 06:00 PM
fix_my_car's Avatar
Default alternator isn't charging the battery.
I just put in a new battery,starter and alternator,but the charge isn't getting back to the battery. I've had it tested by 3 different people and they all say the same thing-everything is running fine but the charge isn't getting back to the battery. Could it be the alternator power cable? or a loose wire?
Old Oct 1, 2010 | 09:04 PM
mark11017's Avatar
Default Re: alternator isn't charging the battery.
check the alt power wire, and the plug for breaks in the wires. there has to be some kind of broken connection for the car to see no charge.
Old Oct 8, 2010 | 03:51 PM
btownprelude's Avatar
hey man did you find the problem i am having the same problem, i have replaced alternator battery starter ground and everything! and checked for breaks in wires and bad fuses but nothing. car dies while im driving, batter keeps charge when its off.
also when battery is low the battery light wont turn on, but does light up when i crank it.
Old Oct 10, 2010 | 05:42 PM
meanshyguy's Avatar
I have the same problem as well, the battery stays at around 13.30 volts while the car is running, checked everything and still no answer, the battery should stay at over 13v while the car is running cuz of the battery, my idea is that something is getting too much volts while the motor is running but can't figure out what it is.
Old Oct 10, 2010 | 06:08 PM
im fixing to redo all my grounds and the power and ground wires to battery. some people have mentioned its possible that could be the problem.
integracura
Acura TSX
Apr 5, 2009 06:42 PM
gsrpedro
14
Feb 5, 2008 01:14 PM
Integ-boy
Nov 26, 2007 06:12 PM
Syndacate
Aug 14, 2007 05:10 PM
dog the bounty hunter
Feb 5, 2006 11:50 AM
