Overheating only when i accelerate?!?
Old Oct 1, 2010 | 04:11 PM
mcamodell's Avatar
Icon2 Overheating only when i accelerate?!?
I have a 1994 honda civic with the D16z6 vtec engine and it is overheating(75% temp gauge) when i accel, and only then. temp is as normal during driving easy and idle. Revving while stopped exibits a rpm intermittent drop from 4.5-3K as I'm holding the throttle steady, after a second, it returns to 4.5K, never having changed throttle position. Fans working fine, coolant, rad and hoses all new. no water in oil, or oil in water, no smoke or smell.
Old Oct 1, 2010 | 04:22 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Overheating only when i accelerate?!?
did u bleed the system correctly?
Old Oct 1, 2010 | 09:38 PM
mcamodell's Avatar
I bled it...I hope I did it correctly. I started the engine and opened the bleed screw near thermostat housing and waited till it dribbled instead of spit.
Old Oct 2, 2010 | 05:46 AM
Retired Moderator
ahh no..
Start engine..
turn on heat at full blast
open cap and watch to see bubbles
add coolant when it gets low
squeeze hoses to help get the air to the top
rev engine a little to move the air in the system..
When u see no more bubbles and the coolant is staying at the top, your done..
Old Oct 2, 2010 | 06:33 AM
Former User's Avatar
Bleeding the cooling system:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
Old Jun 18, 2012 | 08:17 PM
L000nyatick's Avatar
^thank yo
xTimmyx
Feb 5, 2012 11:07 AM
mherrcat
Mar 20, 2011 03:04 PM
cylord
Nov 26, 2010 10:33 AM
JaguarS4R
Honda Civic (2001 - 2005)
12
Feb 28, 2010 04:12 PM
_Endless_
Jan 24, 2004 10:51 AM
