Why would my Civic VX throw code 1?
Old Oct 1, 2010 | 06:31 AM
feret's Avatar
Default Why would my Civic VX throw code 1?
Hi,
I just recently purchased a 1992 Civic VX with about 156k miles. Long story short (and why I'm posting on this thread), the CEL was lit when I bought the car which turned out to be code 48 (LAF).
I tried cleaning the sensor by soaking it in Seafoam for about 12 hours but that didn't do anything. However, I was able to find one at a pull-it-yourself junkyard that happened to get a 1994 VX in that day. I'm not sure of the mileage on that car as someone pulled the dashboard cluster.
Well, after physically comparing the sensors, I swapped them. Unfortunately, the CEL is still lit but it's no longer code 48. Upon jumpering, the CEL blinks on for 1 second, off for 3 seconds, ad infinitum. There are no short blinks. I tried clearing the ECU by pulling the backup 7.5A fuse twice to verify. According to the repair manual I have (1st Ed, 9/91), code 1 (if that's what it interprets to) indicates the Oxygen Sensor for D15B8, D15B7 & D16Z1 engines. My engine is etched with D15Z1.
So I took a closer look at the two sensors. Both sensors look exactly the same: 5 colored wires going to the same plug slots. The only difference is my original one had no markings on the sensor itself but the "new" one only says "L1H1" & "Made in Japan."
Before I dished out the fortune required to buy a new one, I wanted to check with those more experienced than I for any other things I could try.
Thanks!
P.S. I noticed in a forum about the O2 sensor socket being a pricey item. I found that my local Harbor Freight had both a deep socket version & a crows foot version for $5/each, the latter of which was on sale for $4. It works like a champ.
Old Oct 15, 2010 | 08:26 AM
feret's Avatar
Default Re: Looking for suggestions on Civic VX O2 sensor problem...
Hi all!
Just wondering if anyone had any thoughts at all on my previous post? Is there any other information I should add?
Thanks!
-Jeff
Old Oct 15, 2010 | 08:34 AM
Former User's Avatar
Are you sure it's not code 10 (IAT sensor)?
Old Oct 15, 2010 | 12:30 PM
feret's Avatar
Default Re: Why would my Civic VX throw code 1?
Hi Ron,
I'm not sure why I didn't consider that it might be a code 10. I'll see if I can find a replacement TA sensor, once I figure out where it's located. Would the Intake Air Sensor have a drastically negative effect on gas mileage like the O2 sensor would? I'm only getting around 35mpg (in good driving conditions) so far...
Thanks!
-Jeff
Old Oct 15, 2010 | 12:33 PM
Yes, a bad IAT sensor (also called TA sensor) could affect gas mileage. Is it just unplugged? It has a 2P connector with a Red/Yel wire and a Grn/Wht wire.
Old Oct 15, 2010 | 07:02 PM
feret's Avatar
Hi Ron,
Actually, it turns out one of the wires on the harness to the IAT was broken close to the plug. When I went to pull the plug out, the other wire broke. I was able to acquire a new harness but there was no change after I wired it in so I'll try changing the sensor out tomorrow. I'll report back with the results.
Thanks!
-Jeff
Old Oct 19, 2010 | 04:12 PM
aaronhume's Avatar
hey, can I buy your dead O2 sensor? I am doing a VX swap into my LX and I need the plug for the sensor itself... PM me if you are interested please
GsrVtec
Oct 19, 2006 07:33 AM
LoseRPunKx182
Aug 4, 2005 01:50 AM
arw321
Jan 22, 2004 08:33 AM
