I need help,,mixing 100 parts to 2 parts
Old Sep 30, 2010 | 08:44 PM
xrated1's Avatar
Default I need help,,mixing 100 parts to 2 parts
I need expert opinion, iam wonder is that 50-50 mixing ratio ? it is a evercoat polyester primer feather fill g2.
Old Sep 30, 2010 | 10:01 PM
xrated1's Avatar
Default Re: I need help,,mixing 100 parts to 2 parts
Anyone ? any expert painter on here?
Old Sep 30, 2010 | 11:00 PM
EK9Tune's Avatar
It means to put only a little amount like a size of rice. to a big blob of body filler. Watch a video on youtube, most body fillers are like that, don't put too much hardener as it will harden too fast and just crack on you in the long run.
Old Oct 1, 2010 | 04:13 AM
delsoljesse's Avatar
Good rull of thumb for body filler, if your blob/pile of filler is 2in across you mix in a 1in line of hardener, and so on. 8in across would get a 4in line.
Old Oct 1, 2010 | 11:50 AM
xrated1's Avatar
not bondo< Primer g2 evercoat brand> i need to know if it can be thinned. 100 parts to 2 parts.
Old Oct 1, 2010 | 07:13 PM
DC2.2_GSR's Avatar
edit: ahh ****, i suck for not reading the post right... you're talking about a sprayable poly filler! Call Evercoat. if a proper mixing ratio isn't listed on the container then you should be able to call them and get some tech sheet info. i don't use the product and there's almost definitely no one else here who does either. get a hold of the manufacturer, or even just the paint jobber who sold it to you and they'll let you know.
Old Oct 3, 2010 | 11:29 AM
xrated1's Avatar
Thanks, i found the answer and it only can be thinned to 10%. Very little cause it is thick and it is spray on bondo.
rollinswapshop
May 27, 2011 05:10 PM
DonutHands
Honda Ruckus and Scooters
Jun 7, 2010 04:45 AM
Soulless
Sep 6, 2003 01:44 AM
