adjusting skunk2 rear camber kit
i need some help on how to adjust my rear skunk2 camber to where im cambered in the back like this /__\ because right now im not cambered at all im like |__|..and idk how to mess with the camber kit
Loosen the nut at each end and turn the knurled portion, in or out. You can see the camber change. The problem will be getting them equal. I have mine done with an alignment, so that toe is correct. As mentioned through out HT, camber has little affect on wear, but, toe, a lot.
well because im slammed in the front on my coilovers and my camber is /__\ and my back isnt at all and i wanna be both front and back cambered
nah im not jst slammed in the front im slammed front all the way on my coilovers can go and i have like another 2inches to drop in the back but but i need the back to camber thats why i need to adjust it because i lowered the back and right now my tire and my rear fender literally touching thats why i want to adjust the rear camber
true but when i was lowering the back more before i thought it camber and it didnt this is my ride now front coilovers are all the way dwn and back got another 2inches and wheels 15x8 +25 offset wheels dr20's
Sounds like you are going to camber in, and then lower more, which will also camber in. Get an alignment, or have the alignment shop do it all, especially toe. Your wheels are wide, and low offset. You probably have negative camber and now want more for the tires and wheels. Your car and choice of course, but, have it done with an alignment.
yeah i have camber in the front its crazy but i jst want it also in the back ..so prob the thing to do is lower it more in the back and it'll camber in and take it to a shop for the alignment.
Actually it's not off at all..only the odoMeter but idc as long as I'm ****ing slammed tho I dnt go fast bc I'm too Low I have to go slow ha only on nice roads I like to get on it
Probably drives like Sh*T
Camber adjusters can be used for more or less. For track use, negative camber may need to be increased. Problem here seems to be a style that may not be safe, slammed, or stretched tires, with low offset, and using camber to tuck the tire edge under the rim. The stretched tires do not sound safe. You may find that some alignment shops do not want the liability of helping in this.
