Car wont start (no noob question)
Old Sep 30, 2010 | 07:33 PM
Devo94ac's Avatar
Default Car wont start (no noob question)
Ok, The car is a 96 GSR. So the car is obd-2. I am running a obd-1 LS 1.18b. I am using a conversion harness for the ecu. I ahve 2 ECU's P28 P06. It cranks over but does not start.
1. spray starting fluid
car starts and runs everytime
shut car off will not start without starting fluid
2. check the fuel pump
fuel pump is not on when turning key
fuel pump is only running when car is running
3. check main relay
main relay clicks...ok
using 3 different main relays all 3 click
4. make switch to turn fuel pump on and off
toggle switch works and turns on and off fuel pump
fuel to rail complete
going to get a noid light tomorrow to check injector pulse. I'm lost I need help
jerryscherry
13
May 8, 2014 10:08 PM
Elgrys.Mendez
14
Aug 5, 2011 01:26 PM
PatrickFrantz
Aug 21, 2008 05:53 AM
91d15bvtec
Jun 29, 2005 05:08 PM
JDMlyfestyle
25
Oct 16, 2004 11:05 AM
