D17A2 Swapped EF Sedan
Old Sep 30, 2010 | 04:33 PM
dem0nk1d's Avatar
Default D17A2 Swapped EF Sedan
Well I'm think it's time to get back into the whole honda scene once more. I've been thinking about it, and the bug is back. So while looking on craigslist for a good find i came across the goofy swap.
http://yuma.craigslist.org/cto/1931257027.html
Now I know these engines suck, as my search came up with. But also the funny thing is there isn't too much info about the swap. I would do this swap for a last resort, but gets me thinking about the setup. Also you'll notice it's a true d17a2 by the val-cover, but the distributor has me confused, also the stock si intake manifold as well.
I looked and searched for possible write-ups on the swap and nothing... Anyone found any info on this swap? I figure it would be a good time waster for work.
Old Sep 30, 2010 | 04:36 PM
prelude182's Avatar
Default Re: D17A2 Swapped EF Sedan
that would be rediculous. at least you would know the engine itself should have fairly low miles. But from driving one of the newer civics with these engines....they suck *****. kinda like driving a stock vx or cx eg hatch with the stupid long gears
Old Sep 30, 2010 | 04:37 PM
dem0nk1d's Avatar
oh here is another link showing the engine id number.
http://yuma.craigslist.org/cto/1922293866.html
oh and i had no thoughts of even thinking about this car. I just thought the engine swap was a little odd. If i get back into the whole honda scene once more. I'm going to go with something like this...
http://www.civicforums.com/forums/46...g-project.html
none of this JDM crap. too flashy with the neighborhood thieves.
it's all about bone stock looking, and ready for a heavy foot now and then.
Old Oct 1, 2010 | 06:51 AM
dem0nk1d's Avatar
More info about the swap
D17a2 Bolts up to
88-00 Trans
88-00 Intake Manifold
Distributor is from a b16
Engine mounts used on this swap came from the EF. So to set the record on this swap it's pretty straight forward.
Here is my email back from the seller.
"YEAH BRO WELL IM USING A SI TRANNY FROM A 91 CRX AND IT DOES BOLT ON IM USING THE SAME MOTOR MOUNTS FROM THE D SERIES 88-00 IT BOLTS ON WITH NO MODS IM ALSO USING THE SI INTAKE MANIFOLD AND A B SERIES DIZZY FROM A B16 ANY MORE QUESTIONS IF U WANT PICS I COULS SEND YOU SOME BRO"
Old Oct 1, 2010 | 11:51 AM
SIef9's Avatar
so since he pretty much did what everyone does on a ef with a single cam vtec swap would this one be faster than a d16z6, Y8????
Old Oct 1, 2010 | 12:31 PM
dem0nk1d's Avatar
I haven't really spent the time to research the d17, and what the possibilities are with it. It all comes down to the build and ultimately the tune. So if your going to tune it you'd wanna convert over to the obd1 system.
Old Oct 1, 2010 | 12:36 PM
dem0nk1d's Avatar
D17A2
  • VTEC
  • Found in:
    • 2001-2005 Honda Civic EX (US only)
    • 2001-2005 Honda Civic LX (Europe)
    • 2001-2005 Honda Civic Si (Canada only)
    • 2001-2005 Acura 1.7 EL (Canada only)
    • 2000-2007 Honda Stream 1.7 (Japan)
      • Displacement : 1,668 cc (101.8 cu in)
      • Bore and Stroke : 74.98 × 94.4 mm (2.952 × 3.72 in)
      • Rod Length : 137 mm
      • Rod/Stroke : 1.48
      • Compression : 9.9:1
      • Power : 127 hp (94.7 kW, 132 ps) @ 6300 rpm
      • Torque : 114 ft·lbf (114 ft·lbf USDM[4]) (15.8 kg/m, 155 Nm) @ 4800 rpm
      • RPM redline: 6800 rpm
      • Rev-limiter : 7200 rpm
      • Valvetrain : SOHC VTEC (4 valves per cylinder)
      • VTEC Switchover : 4500 rpm
      • Fuel Control : OBD-2 MPFI
Old Oct 1, 2010 | 12:38 PM
SIef9's Avatar
well i was just wondering stock.. no bolt ons or nothing... it seems pretty interesting i onced thought about this swap n asked around if this would bolt on like the other single cam vtec's do but everyone said they doubt it...
Old Oct 1, 2010 | 12:43 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
I want to know how the distributor was bolted on. Does the head have the threaded holes for it, and does it line up? I am guessing the stock cam has the slot for the distributor already.
Old Oct 1, 2010 | 01:26 PM
dem0nk1d's Avatar
I've attached side by side shots of the d17a2 vs d16z6. Pics are hi-res so you can zoom in for more detail enjoy.
Old Oct 1, 2010 | 02:34 PM
hush22's Avatar
ROLLER ROCKERS FTW
Old Oct 1, 2010 | 03:21 PM
wreckin-rex91's Avatar
ugh.... (shudder..) D17.... those were some dark years for the ole' civic. Good for grandma's and tree huggers and all... but as a Honda lover I try to forget those years happened.
Old Oct 1, 2010 | 11:33 PM
DCRB's Avatar
so wait... the d17 looks like the the vx head set up, where it goes from 12 valve to 16 valve not from 16 valve to crazy mode... how is that beneficial? i mean if you're going for fuel economy i guess that's ok...
Old Oct 2, 2010 | 05:39 AM
singlecamsaint's Avatar
yeah but could you set it up to go from 16 valve to crazy mode or would you have to keep it that way
Old Oct 2, 2010 | 07:48 AM
dem0nk1d's Avatar
The combustion chambers don't look to bad on the d17 head. Little bump in compression. Also the intake ports look like they would need to be filled in with some devcon liquid aluminum, and then port matched.
Old Oct 2, 2010 | 11:56 AM
JDMhonda90's Avatar
d17a2 are slow, i spank does vtec motors on my single cam d15b2 all motor no vtec just mpi swapped
Old Dec 23, 2024 | 07:36 PM
Denbees02's Avatar
[QUOTE=dem0nk1d;43670749]More info about the swap
D17a2 Bolts up to
88-00 Trans
So the engine mounts won’t have to be moved at all?
TYPE WAHH
Apr 17, 2010 08:58 PM
ZumCRX1
Jan 2, 2010 04:01 PM
boostdeliquent
41
Aug 8, 2006 05:59 PM
b-16delslow
Jul 11, 2006 06:43 PM
