What is the Diffirence Between Type S prelude and Type SH ???
The Type S Prelude has 10 more horsepower and torque over the SH or the base (200HP, 170TQ Est.). The Type S is only made in Japan.
The Type S motor comes with higher compression, more aggresive cams, and larger Intake manifold plenum.
I think he's referring to the usdm type s to type sh, which would be a different block design(to fit atts unit),A different Differential in the transmission to allow the atts unit to work, and atts unit/control module.
The Type S Prelude has 20 horsepower and 7 ft·lbs of torque over the SH or the base (200HP, 170TQ Est.). The Type S is only made in Japan.
The Type S motor comes with higher compression, more aggresive cams, and larger Intake manifold plenum, a dual-chamber intake, redesigned header, Active Control ABS, Digital Climate Control, carbon fiber gauge bezel, carbon fiber CC & radio trim, and no sun-roof.
Now, if the OP was asking the differences between the USDM base model and the USDM Type SH, check the FAQ.
haha
