Broken valve cover bolt - How fix?
Old Sep 30, 2010 | 11:25 AM
deebo's ek9's Avatar
Default Broken valve cover bolt - How fix?
whats up people so i removed my valve cover to paint it and when i was putting it back on one of the screws broke wile i was tightning it, will something go wrong without it ? and how can i fix it
Old Sep 30, 2010 | 11:28 AM
Former User's Avatar
Default Re: Broken valve cover bolt - How fix?
You need to remove the remnant of the broken bolt and install a new one.
Old Sep 30, 2010 | 11:33 AM
can i run the car with out that bolt
Old Sep 30, 2010 | 11:42 AM
Ci-v-iC's Avatar
You can but monitor for oil loss often and replenish when needed.
Old Sep 30, 2010 | 11:46 AM
ok cool ill take it to the shop do you guys thinck its expencive to get it removed?
Old Sep 30, 2010 | 11:55 AM
Is the broken bolt protruding above or recessed below the surface of the head? Post pictures.
Old Sep 30, 2010 | 12:02 PM
i dont have a camera but its flush to the block
Old Sep 30, 2010 | 12:09 PM
So the broken bolt is flush with the head when the valve cover is off?
If the broken bolt is slightly above the head, then you may be able to score a groove in the top with a Dremel tool and remove the remnant bolt with a screw driver.
Otherwise, drill a small hole down the center of the bolt and remove it with a reverse-threaded screw/bolt extractor.
Old Sep 30, 2010 | 12:14 PM
that sound better ok man thanks
Old Sep 30, 2010 | 06:58 PM
EJeff8's Avatar
^I use the dremel method often, pretty easy. But if it's flush, you may not want to put a dremel line in the head of that bolt hole.
Old Sep 30, 2010 | 10:01 PM
dxlol's Avatar
just use a small screwdriver... i broke like 3 of them on my d16z6 and got them all out. then i replaced them with brand new ones.
Animefun
Oct 28, 2012 08:55 PM
EK squid
18
Jul 13, 2011 08:59 PM
00ekcoupe
37
Sep 5, 2005 06:15 PM
renzema
Aug 29, 2005 09:42 AM
happy_guy
Aug 9, 2005 06:36 PM
