Need to know location on ecu for cam or crank sensor
Old Sep 30, 2010 | 10:11 AM
Acidcrakker's Avatar
Default Need to know location on ecu for cam or crank sensor
Im installing a zrtronix datalogger unit. Im getting a shitty signal off the tach line. Thats what the zetronix people say anyway. I have 2 other tachs running off that line and they are fine. They told me to tap into my cam or crank signal wire to reduce noise. I actually dont know what wire that is. I know its dizzy related but not which wire.
Old Sep 30, 2010 | 06:43 PM
Default Re: Need to know location on ecu for cam or crank sensor
So Im looking at the actual Crankshaft postioning sensor. Seems like the only sensor that might display this.
Now I find this odd, but the people at Zeitronix says that it will work. I have never heard of this before.
Can anyone actual confirm or denie this?
Id like to get this sorted out. I think its hardware issues, not connection.
Old Oct 2, 2010 | 05:33 AM
Does anyone know where I can get a Variable Resistance Potentiometer 50-100k Ohms Liner Pot From?
I called radio shack and they don't carry it.
Old Oct 22, 2010 | 03:53 PM
flyrod's Avatar
You can probably find one online, like at mpja.com or similar. If you can find a 0-50k, you can just add a 50k resistor to it. Good luck.
Old Oct 22, 2010 | 03:57 PM
Thanks taken care of already. Im glad there is still someone on this fourm with some real knowledge here.
balbowskie
Engine Management and Tuning
Jan 29, 2012 02:31 PM
hbyrd8701
Jan 18, 2009 12:56 PM
i_VTEC
Nov 20, 2008 10:34 PM
