How install Energy Suspension tie rod dust boot on 92-95 civic?
It shouldnt be any different than stock I would think? did you already remove the old boot and spring? put the energy boot on and use the factory spring.
im not sure thats why i was asking but its this one http://www.energysuspensionparts.com...prod=16%2E8102
Does this help for the shock mount bushings?
http://www.energysuspensionparts.com...sion/17162.pdf
When I did my tie rod boots, I took the tie rod ball joint out of the knuckle, removed the OE rubber boot, packed the ES poly boot with high temp grease, reinstalled the boot, and reinstalled the tie rod.
HatchBox
13
Oct 24, 2004 06:00 AM
