JDM B20B on boost
Not really. The cylinder walss are really thin. I would highly recomend that build teh bottom end if your going for that much power, if you were only shooting for 200hp, it probably wouldnt be that big a deal. If you search this topic, there should be some good info on here about it. Also try researching on team-integra.org. Some good infor on there.
heres a link to the turbo FAQ's on team-integra: http://www.team-integra.net/forum/di...PagePosition=1
Try here too: https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
okay well wat i wanted to do is put a t03/t04 on my jdm B20b which has about 40*** miles and i wanted to tuned with Hondata at CFT........would the motor hold a guud 230-250 Whp ?
Just make sure you have a really good tune, good cooling system and run NGK BKR 7E-11 plugs and you should be good.
