tachometer not working
i need some help my rpm gauge isn't working. well it works then it doesnt. it works when i freakin wants to. i wanna know is their like a fuse or wire or something that works it???? thanxxx. ^_^
lmao i dunno why i was thinking speedometer.
yea rpm gauge acting up is either a loose wire at cluster, faulty gauge, or ignition coil in the dizzy is on its way out.
thats for the speedo. you may have a loose wire in your dizzy. the dizzy has a blue wire that goes to the ecu and the tach. check all the connections in the 2 plug harness on the dizzy.
the rpm's are monitored by a sensor in the distributor. maybe try a different dizzy if you have one laying around. if not that the cluster could be screwed
pdcivic
14
Jun 25, 2003 09:26 PM
xXx Justin xXx
Jun 13, 2002 07:20 PM
