2002 civic - driver door does not lock/unlock with key fob
Hi,
I have 2002 civic coupe EX. Recently my driver side door cannot be locked/unlocked by the key fob, whereas the passenger side door lock/unlocks fine. Whenever I press the lock/unlock key on the fob, the front and tail lights flash as usual.
Even when I use the central lock on the driver side, the passenger door lock/unlocks but the driver side does not.
Any suggestions on on how to find the issue and fix it?
Thanks
Thanks
now, i have the opposite problem. I did replace the door lock actuator on the driver side. does that control both doors? I'm assuming it does since before the actuator went, I could lock/unlock both doors with the driver side door. Now that I've replaced the actuator, the driver side locks/unlocks with the keyless entry but the passenger side doesn't work and I cannot control the passenger side door lock with the driver side. Could it just be a loose wire on the driver side? Or is there something amiss on the passenger side?
thanks,
Lis
thanks,
Lis
domenic
Apr 11, 2010 02:37 PM
Intercooler
Nov 18, 2004 08:43 PM
