Suspension & Brakes Theory, alignment, spring rates....
crazy front tend shake
Old Sep 29, 2010 | 02:04 PM
wannaBjdmca6's Avatar
Default crazy front tend shake
so it all started when i replaced my axles cause they were clicking under load.
then the new axles were VIBRATING under 2nd gear. and little later i start getting this crazy front end shake at above 60 MPH at first i thought it was an alignment so i got one. but didnt fix it. so then i balanced my wheels. didnt fix it then i rotated the wheels cause i one was slightly bent but that didnt help.
what can be the problem?
replace the brand new axles?
Old Sep 29, 2010 | 08:41 PM
dubzxallxstar's Avatar
Default Re: crazy front tend shake
motor mount, tranny mount, wheel bearing
Old Sep 29, 2010 | 10:00 PM
i was reading more and seems like i need hub centric rings because my enkei's bore is bigger than the outer bore of my hub. by alot i will measure 2m.
but on the shaking under load. i really think is the axles i replaced the driver lower mount cause it was the only one torn up but didnt fix it. who knows maybe is the hub centric rings as well
dc2era
May 3, 2009 06:26 PM
JDM SIR-G
Dec 15, 2008 11:18 AM
xtremegsr273
Jan 25, 2006 12:53 PM
joshmycell
Dec 4, 2004 07:53 AM
darkslide_77
Oct 4, 2004 05:03 AM
